ATF in transfer case?
Old Dec 23, 2019 | 04:59 PM
Kevin Drain's Avatar
Default ATF in transfer case?
I believe read somewhere that someone had used the same fluid for the automatic trans in their transfer case (can't find it now). This seems questionable to me, however, I do have some extra Castrol Multi-Vehicle ATF leftover. Can the transfer case be filled with this, or should I only use the 75/140 synthetic gear oil I have seen recommended? Thanks!
Old Dec 23, 2019 | 11:49 PM
Dell Gailey's Avatar
Is it April Fool's Day?
Old Dec 24, 2019 | 01:40 AM
Thermo's Avatar
Veteran: Navy
PUtting ATF in your transfer case will only last you for a very short period of time until you end up destroying the transfer case. The use of the synthetic 75W140 gear lube is a must. The big reason is that the full synthetic fluid has a high resistance to crushing under heavy loads. What does this really mean. The gear lube will maintain a certain amount of lube between the gears when you are accelerating due to the thickness of the fluid. Where the ATF fluid is going to be crushed and squirted out the sides, allowing for metal on metal contact. This is going to result in a very short life span of the transfer case.
robertorolfo
Aug 5, 2016 05:43 PM
jag2020
Nov 7, 2010 03:53 PM
Rockyf
Oct 30, 2010 11:48 PM
MattSteele
Oct 14, 2010 11:20 PM
Dragonsse
Jul 20, 2008 08:25 PM
