auto transmission fault
Hi all have a problem with my auto box it's on a 3.0 2001 done 100k it seems to miss 4th gear we accelerating fairly not too hard it revs and takes a while to engage but if accelerating gently it's ok no other gear is affected and today for the first time it came up gearbox fault stopped switched off engine re-started and gearbox fault goes any help is it termnial!!!!!!!!!!! or would a fluid change do the trick
I had exactly the same issue on my car 3 years ago. Unfortunately it was an expensive fix due to a failed solenoid which caused a clutch pack to burn out. The code that was thrown was P0734 4th Gear Out of Range.
Here is the link to the UK forum where I outlined the issue in a little more detail: Gearbox fault - P0734
Regards
Rob
Regards
Rob
aholbro1
Dec 29, 2024 06:46 PM
SouthernGypsy
Sep 23, 2015 04:06 AM
