auto transmission fault
Old 05-26-2014, 01:04 PM
fourbyfourbyfar's Avatar
Default auto transmission fault
Hi all have a problem with my auto box it's on a 3.0 2001 done 100k it seems to miss 4th gear we accelerating fairly not too hard it revs and takes a while to engage but if accelerating gently it's ok no other gear is affected and today for the first time it came up gearbox fault stopped switched off engine re-started and gearbox fault goes any help is it termnial!!!!!!!!!!! or would a fluid change do the trick
Old 05-26-2014, 07:59 PM
car5car's Avatar
How is fluid?
Old 05-26-2014, 11:20 PM
Slocs's Avatar
I had exactly the same issue on my car 3 years ago. Unfortunately it was an expensive fix due to a failed solenoid which caused a clutch pack to burn out. The code that was thrown was P0734 4th Gear Out of Range.
Here is the link to the UK forum where I outlined the issue in a little more detail: Gearbox fault - P0734
Regards
Rob
Old 05-27-2014, 01:23 AM
so you had to have a clutch pack and solenoid or just the solenoid ? the solenoid looks easy to change in the manual
Old 05-27-2014, 05:10 AM
Slocs's Avatar
It needed both, which I understand was a transmission out job. Unfortunately here in Australia labour costs are somewhat high!
Regards
Rob
Old 05-27-2014, 06:53 AM
thanks for that
tomsjag
06-10-2023 10:02 AM
aholbro1
08-05-2021 05:02 AM
SouthernGypsy
09-23-2015 04:06 AM
tonyforman
09-10-2015 07:23 PM
AtholC
09-09-2015 09:07 PM
Quick Reply: auto transmission fault
