Bad computer question.
Old Nov 15, 2017 | 05:39 PM
innzane's Avatar
Default Bad computer question.
I am looking at an 02, seller says it has a bad computer. Wondering what the symptoms of that are. What should and should not work.
Any crazy things need done to replace the computer beside the physical install?
Thanks for info!
Old Nov 16, 2017 | 12:30 AM
JagV8's Avatar
Seller is likely wrong.
You either buy on a whim or get some proper info or walk away...
Old Nov 18, 2017 | 09:41 AM
innzane's Avatar
Chances are seller is wrong, very possible.
That is why I am asking for some proper info.
would car be dead? any dash lights? will a code reader read a computer fault code?
Old Nov 18, 2017 | 10:17 AM
Alfadude's Avatar
You might try asking the seller that very question. What leads him to believe he has a "bad computer"? ECM? TCM? Something else? Does it start, but not move? Any lights on? Anything flashing? What were the circumstances when it failed? What, if anything, has he tried to fix it?
Not enough info to even start trying to diagnose.
Old Nov 19, 2017 | 09:16 AM
innzane's Avatar
Yeah, I am not trying to diagnose it. More fishing for info so I can make an assessment of it.
Seller claims the car is dead, no crank or anything. The result of hitting a big pothole on the highway. I like to think I pay the 1K for it, reset the inertia switch and drive away, but my luck is no where that good.
My best guess is the main harness broke at the firewall connection. Just a hard one to research with the number of computers in it.
Seller seems frustrated, I get one and two word responses from him. Here is a link, I am after a low mileage pre 04-1/2 to replace my 02 x.
https://martinsburg.craigslist.org/c...385522345.html
Old Nov 19, 2017 | 10:32 AM
avern1's Avatar
Myself I would offer $500.00 and send the tow truck. The ECU connector is a very robust connection with a bolt thru the center to keep everything connected. I doubt it was damaged by a pothole. You are most likely correct that it is the Inertia Switch. It cuts all electrical power to the systems and cuts off fuel pumps.
Just my 2 cents.
Old Nov 23, 2017 | 11:52 AM
innzane's Avatar
Worth a shot I suppose
Thx for the 2 cents
