Bad Hi beam
I have a 2004 X-type2.5, my high beam on the drivers side went out.
The number on the bulb is H1-BL-05314,it has a red and a black lead.
I think it is a HID Zenon, I can't find one anywhere, I called Jaguar and
they wanted $250 for a bulb. Can I bypass that ballast assembly and
use a H1 bulb, the bulb sockets appear to be the same size. Any
information or suggestion would be appreciated. Thanks
The high beam bulbs are not HID the low or dip beam is HID if it has a ballast and an igniter mounted to the back of the bulb. H1 bulbs are off the shelf at auto parts stores. You can plug and play with the bulb.
The HID bulb is a DS2 bulb and is round based where the H1 is blade based.
If the high beam and low beam bulb connectors look the same then you don't have the HID variant headlight system with ballast and igniter.
Was googling while the other replies were posted
As stated, the factory xenon is low beam
Bulbs, wipers for your JAGUAR X TYPE SALOON HID XENON 2004 (04)
Amazon.com: x type jaguar H1 bulb
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
Oct 12, 2015 03:16 PM
