Battery Cables - what gauge?
Old May 15, 2014 | 10:23 AM
slenser's Avatar
Default Battery Cables - what gauge?
Does anyone know what gauge wire is used for the battery cables? I'm going to try fixing them before replacing and I'm wondering what sized connectors I should be buying.
Old May 15, 2014 | 01:30 PM
I found your question posted at the end of a newbie Intro made today and have moved it to X-Type forum.
Members here with the same model will be able to help.
Old May 15, 2014 | 07:50 PM
Thermo's Avatar
Veteran: Navy
slenser, when it comes to making your own battery cables, I would say that bigger is better. I would say to star with something along the lines of say 4 gauge wiring, but upgrade to 2 gauge if you feel it necessary. Granted, if you are going this far, you will also find it beneficial to upgrade the ground wires between the battery and engine block and the battery and body. While most people thing that the ground wires are more than sufficient, do the upgrade. It only costs a little bit and the benefits are well worth it.
Old May 15, 2014 | 10:30 PM
slenser's Avatar
Actually, I was wondering what gauge the factory ones are. After some research, I've found people are saying it's the end connectors that end up corroding and need replacement.
Building my own is definitely an option, if it's cheaper than buying.
Old May 16, 2014 | 06:55 AM
Thermo's Avatar
Veteran: Navy
slenser, I am going off of memory here, but I believe the factory wiring is 6 gauge. Granted, could be 4 gauge too. The terminals that you can buy will handle both 4 and 6 gauge wiring with the same connector.
Old May 16, 2014 | 08:28 AM
slenser's Avatar
Thank you, Thermo! I'll pick them up today.
Old May 16, 2014 | 01:30 PM
kashaf's Avatar
It is definitely cheaper if you can just change terminals on the battery. mine corroded too. I changed all the wiring in my car to 1 gauge and you can buy those cables with terminals preinstalled on them.
Battery to Starter
Battery to Ground
Battery to Alternator
Thing with jaguars is that they need a lot of juice to get it going so make sure you have a tight and secure terminal connection to your battery posts. I would also check to see if any corrosion got to the copper inside your cables because if it did you should replace your cables aswell unless you want to pay for a new alternator.
Old Feb 20, 2025 | 02:50 PM
Mayoj5999's Avatar
Default Battrey
I can find out when you gals get home….
Old Feb 23, 2025 | 12:17 PM
Jo van Haag's Avatar
slenser, there is little to add to what Thermo wrote. 5 gauge is absolutely unacceptable. In Germany, at least 25mm² is used, which corresponds to 3 gauge. I don't know of any smaller ones, maybe because we only drive cars with more than 2.0l. But an upgrade from 3 to 2 gauge can only be positive.
Old Feb 24, 2025 | 02:21 PM
slenser's Avatar
While I appreciate y'all answering my question, this post is over a decade old. I have long since moved on to something else, but hopefully someone else will find this info helpful
99xk8guy
May 28, 2024 09:36 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tsimms7
Sep 15, 2015 12:43 PM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
Bcrary3
Sep 3, 2015 03:48 PM
