Battery connected backwards
Old Aug 2, 2012 | 06:15 PM
okstate734's Avatar
Default Battery connected backwards
I accidentally attached the battery backwards on my 2006 x type, yea I know! I am just wondering if there is a fusible link that protects the electrical system. If not, what kind of damage am I looking at? Hopefully I just burned some fuses but I'm not that lucky. I have not replaced the battery on it yet so I'm not sure if the car will start or not. Any help or advice will be greatly appreciated.
Old Aug 2, 2012 | 06:34 PM
Jac's Avatar
Jac
Hook the battery up correct and let us klnow what happens. I don't think that you did any damage except for maybe blowing a fuse. I could be wrong but I'm sure somebody on here could help you.
Old Aug 2, 2012 | 06:40 PM
A lot depends on whether you switched on the ignition.................
All you can do is reconnect the right way round and try it.
Old Aug 2, 2012 | 07:18 PM
Thermo's Avatar
Veteran: Navy
LIke GGG said, hard to say what happened. Connect up the battery correctly and give the key a spin. From there, you can see what does and does not work. From there we can figure out what needs to be done.
Old Aug 2, 2012 | 11:18 PM
okstate734's Avatar
Thanks for the replies! I will let you know what happens with the new battery. Luckily I didn't turn the key while it was connected backwards.
Old Aug 2, 2012 | 11:53 PM
disguay's Avatar
I'll admit to doing this too, and I didn't turn the key so all that happened is that I needed a new battery cable to be safe. Hopefully the worst that happens is that you feel like an idiot... That's what happened to me. Just felt like and idiot and one battery cable. If you turn on the ignition, you're screwed.
Old Aug 3, 2012 | 03:16 AM
Then you could have just had one very lucky escape!
Old Aug 3, 2012 | 09:15 AM
okstate734's Avatar
OK guys, attached the new battery and the alternator popped and smoked. How do I get the alternator off?
Old Aug 3, 2012 | 09:33 AM
steveinfrance's Avatar
Someone who knows the X type will help but the chances are you've only fried the diodes/voltage regulator not the whole thing.
I don't imagine, being a Jaguar,that the unit can be removed without removing the alternator but it isn't an expensive item.
Again an X type can tell you if it's easy to take the connector off the alternator which would let you turn the key and find out what else is toast.
Old Aug 3, 2012 | 09:39 AM
Aaagghh!
JTIS procedure calls for removal of the AC Compressor but I'm sure the guys will have away of avoiding that.
The alternator disconnect and removal procedure is:
JTIS - X-Type 2005 Generator.pdf
Old Aug 3, 2012 | 09:45 AM
Good old Jaguar. They never let you down do they?
Looks like you can disconnect the big battery lead (and stop it from touching anything) and pull the other connector with the alternator in place to try turning the key.
Obviously disconnect batt gnd before + reconnect after!
ps looking at Graham's pdf you might just be able to get the module off in-situ - obviously it's the plastic bit the wires go into.
Old Aug 3, 2012 | 10:55 AM
okstate734's Avatar
Thanks so much! I will try and see if I can get it off without removing the alternator.
Old Aug 3, 2012 | 12:44 PM
okstate734's Avatar
So what are odds that the module is the only fried part. It looks like there is a metal cover with about 4 small nuts holding it on. I assume the module is under that? I can't figure out how to get the alternator out even if I removed the ac! It looks like I should remove the cooling fan assembly to get it out. I really don't want to do that. Also, the pivot bolt won't budge. This has become a major pain in my ***. Any suggestions?
Old Aug 4, 2012 | 02:36 AM
I can pretty much promise that the bit with the 4 nuts will be the only fried part of the alternator.
On all the alternators I've seen (and don't forget I'm not an X-type) the electronic module will lift off the alternator body with a couple of small carbon brushes that energise the alternator via slip rings.
My anxiety is what else on the car has also gone pop.
That's why I suggest disconnecting the alternator and turning the key.
Old Aug 4, 2012 | 06:45 AM
okstate734's Avatar
Turned the key (without alternator) and the only thing I could see that didn't work is the radio. Hopefully it's just a fuse! Still haven't got the alternator out, guess I'm gonna take it out the fender well unless someone has a better suggestion. I had to order one and I get it tomorrow. I will keep you advised! Thanks for all the replies and suggestions.
Old Aug 4, 2012 | 06:53 AM
Looks like you've mainly got away with it. Did you try a start?
Old Aug 4, 2012 | 08:04 AM
Steve,
I remember reading either you shouldn't run with an alternator disconnected or shouldn't run with a battery disconnected.
Being a complete p**t, I can't remember which it was....................
Old Aug 4, 2012 | 08:14 AM
Graham,
It would be the battery because it is it that clamps the +ve supply.
If you think about it if an alternator goes t*ts up you can still start the car until the battery gets too flat.
I imagine OP will get some messages about no charge but if it runs he hasn't fried the ECM.
Least that's my take on it but I'm a fully paid up JF-OF member as you know and am frequently wrong.
Last edited by GGG; Aug 4, 2012 at 08:28 AM. Reason: Gallic humour may not travel!
Old Aug 4, 2012 | 08:29 AM
Steve,
Thanks for the clarification. I'll put that on a PostIt Note.
Old Aug 4, 2012 | 09:10 AM
okstate734's Avatar
Haven't tried to turn it over since I havent gotten the alternator out yet. Did a test on the computer and it seemed to go through all the checks ok. Hopefully I can get the pivot bolt out! It still won't budge and now it's rounded off. Have tried everything I know and it won't budge. It acts like it is left handed threads(Its not is it?) I will keep updating and I'm sure ask for more ideas. Like how to get the bloody thing out of the engine bay!
