Battery Light
Old Jul 21, 2014 | 01:49 PM
Kgreen1's Avatar
Unhappy Battery Light
I have a 2006 X-type jaguar and my battery light comes on intermittently. But, when it come on the voltage drops to (about) 12.33 volts. I replace the alternator and still having the problem. This one has me confused, because sometime it comes on and sometimes it doesn't. I also replaced the battery due to the constant drop in voltage. Are there any suggestion?
Keith
Old Jul 21, 2014 | 03:06 PM
jimborino's Avatar
Battery cables? From what I've read (and experienced in other cars) bad grounds / dirty connections can cause this sort of thing ...
Old Jul 24, 2014 | 01:02 PM
Kgreen1's Avatar
Default Battery Light
I checked the cables to ensure that the ground was tight. I was told that if there was a loose ground that the positive cable would be hot when the problem started. Checked it again when I replaced the battery, sorry, I should have mentioned that in the initial post.
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
OkieTim
Sep 8, 2015 04:48 PM
edtexas
Sep 4, 2015 08:20 PM
OkieTim
Sep 2, 2015 12:48 PM
