Battery light on -- intermittent
Old Apr 12, 2013 | 07:06 AM
Wahooesprit's Avatar
Default Battery light on -- intermittent
car is a 2002 x type
Have installed just because of age and preventative measure:
New Jaguar positive battery cable
new Jaguar negative battery cable
new cable from battery to fuse box
new battery
Everything was great until I put a new stereo in from Crutchfield--used their harness--now the battery light comes on about once a day *only* when you plug the usb cable from my iphone into the stereo....
Alternator was charging but now I am wondering...anyone else ever seen this problem?
Old Apr 12, 2013 | 08:56 AM
bracester's Avatar
Ya typically that's an alternator issue, but on this car it seems that what I think it normally should be indicated by lights its typically not...lol
Old Apr 15, 2013 | 09:51 PM
cujet's Avatar
Like others here, I found the positive cable to be scalding hot, when heavy loads were applied.
I turned on the air-cond, the high beams and the rear running lights, plus cranked up the stereo. Within a few minutes, the battery voltage was down to 12.0V and the positive cable was 300 degrees and climbing (at the crimp from cable to terminal lug)
Fixing that solved my battery light issue.
Old Jun 19, 2013 | 03:58 PM
kdflynny's Avatar
Hi cujet - how did you fix the issue? I am having the battery light issue as well. All things seem to check out fine - alternator, battery, etc. If you turn the car off the light goes off but after starting back up and driving a bit the battery light comes back on. Bizarre - mechanics cant find the problem.
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
OkieTim
Sep 8, 2015 04:48 PM
edtexas
Sep 4, 2015 08:20 PM
OkieTim
Sep 2, 2015 12:48 PM
