Bill's TC Kit- Differential
Does anyone have a write up of how to use the kit for a rear differential oil change. The kit was awesome and very easy to use for the Transfer case change, highly recommended. Now i want to tackle the rear differential and a write up would be nice. Any help is appreciated.
Howdy. There is a semi-write up in the FAQ section under Diff-oil-change I think it is called. Here is the link.
https://www.jaguarforums.com/forum/s...ead.php?t=3984
Basically it involved pumping out the old fluid or at least what use to be fluid (not draining) and refilling with new.
I have not used the Kit but have heard it works on the rear so you should be good to go.
Cheers!
Cheers!
Woznaldo
Sep 26, 2015 11:02 AM
