Bleed ABS Unit Manually
Old Jun 11, 2022 | 03:45 PM
Tomjones's Avatar
Default Bleed ABS Unit Manually
Hi
I had to removed the ABS unit, afterwards I did a complete fluid flush ..
but the Break pedal now hits the floor ....
There is definitely no air in the brake lines... I have read in some of the Threads to bleed the ABS Unit and Master Cylinder
I did assume if there was no air in the lines, there be none in the ABS unit,, Any suggestions on how to bleed the unit ?
is it as simple as pedal down losen screw, then tighten and pedal up ? (I had only one person so couldn't try this)
(I replaced a unit on a BW Troubleu before and didn't have to bleed the unit )
Old Jun 12, 2022 | 05:37 AM
Tomjones's Avatar
For my own update
I found this on the Fourms
https://www.jaguarforums.com/forum/a...m-bleeding.pdf
Slave cylinder ,, not Master Cylinder ,, its all in the wording
Old Jun 12, 2022 | 06:24 PM
Dell Gailey's Avatar
Uummm... not really
What is the Clutch Slave Cylinder? The clutch slave cylinder plays an important role in vehicles with manual transmissions. The slave cylinder works in tandem with the clutch master cylinder to disengage the clutch and shift the transmission when the pedal is pressed.
In automotive engineering, the master cylinder is a control device that converts force into hydraulic pressure. This device controls cylinders located at the other end of the hydraulic brake system.
Old Jun 13, 2022 | 03:58 AM
Tomjones's Avatar
Cheers.. What I meant was, I was searching Mater Cylincer
but should have been searching slave Cylinder
Although my slave cylinder looks different to the one in the diagram
I ve another Thread asking for the part to be Identified ,,,
https://www.jaguarforums.com/forum/x...ne-bay-259787/
Old Jun 13, 2022 | 07:09 PM
part number is c2s46903
marculix
Feb 16, 2022 03:50 AM
John Broski
Dec 15, 2020 01:01 PM
BlackQueen
Feb 5, 2015 03:15 PM
bekcon
Apr 3, 2013 12:35 AM
jag01xk8
May 22, 2012 02:06 PM
