Blew a hole in the radiator tank ...
Old Dec 3, 2012 | 07:12 PM
Sam1's Avatar
Default Blew a hole in the radiator tank ...
Long story short, was cruising down the interstate at a high speed, temp shot up and steam came out. Pulled over, let it cool off & repeated and got to a gas station. Found about a 1/2" hole on the plastic end cap, repaired it by melting some plastic tape into the hole, then sealing it up with a heavy epoxy (made it home two hours away without it losing another drop of coolant lol).
Anyways, I need to get a new radiator and cannot find anything that has metal end caps. Does anyone know of where to get one? Don't mind to pay the extra $, I would just like a good one. Will probably end up having to put a plastic one back in because I didn't see anything else available, but thought if it did exist, someone here would know.
Old Dec 4, 2012 | 04:24 PM
Dave333's Avatar
Default Here ya go...
It's 3 times the cost of the aluminum/plastic one but it won't fall apart as easily.
Just go to Summit's website. Part number is PLI-431513. Cost is $368.95. They also have the aluminum/plastic and those are $110.95 part number SGT-CU2256.
Hope that helps.
Old Dec 5, 2012 | 05:33 AM
Sam1's Avatar
That $300 one will fit in the x-type without needing to be modified? Price is fine if it will, but it says it's for an xj6/xjs
Old Dec 6, 2012 | 12:47 PM
Dave333's Avatar
You're right. I don't think it'll fit without modification. Sorry about that.
Old Dec 6, 2012 | 07:27 PM
Sam1's Avatar
ok thanks for the info though. guess we're stuck with the plastic crap
Wahooesprit
Dec 23, 2019 02:01 PM
Poet
Oct 6, 2015 09:40 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrplow58
Sep 9, 2015 11:27 AM
1100me
Sep 7, 2015 06:26 AM
