brake locking
Old Nov 28, 2018 | 06:31 AM
eidingen's Avatar
Default brake locking
My jaguar xtype has problems with brake.
all four are locking after i am driving for some while!!allready changed master cilinder,calipers repaired......whath could be the problem??????
Old Nov 28, 2018 | 01:07 PM
Thermo's Avatar
Veteran: Navy
Sounds like a problem with the ABS unit. You have replaced the other common components and since it is affecting all 4 wheels, that narrows down what the possible source of the problem is. If you do some looking here on the site, others have had the same issue and you can get a few checks that you can make to help confirm what I am saying.
Old Nov 28, 2018 | 01:37 PM
Dell Gailey's Avatar
Did you or anyone do brake work recently (pads, bleeding, etc.)? If so read this ENTIRE thread for a possible cause, reason and fix =
https://www.jaguarforums.com/forum/x...-208617/page2/
If not that then as Thermo said, probably ABS module.
Old Nov 28, 2018 | 07:50 PM
dennis black's Avatar
very easy! your brake booster is the problem ,when you changed the master cylinder theirs a rod in the booster it has 7mm nut on the end
get a friend to push the pedal all the way down
2 = get a needle nose and grab the stem the turn the 7mm nut on the end 3 -4 times in bolt it back together and your done
doooooo not buy a new booster just adjust the one you have the way i told you
euphonium01
Jan 24, 2023 02:50 PM
Forrest Keith
Nov 20, 2022 05:06 PM
MikeofBonsall
Dec 2, 2018 03:56 AM
