Bulb Replacement!
Old Jan 29, 2010 | 07:40 AM
zyggo's Avatar
Originally Posted by muddyjag
the slam panel is the panel the bonnet closes on ,the flat panel above the headlights,there is a small hole in it that you can poke a long screw driver through and just reach the clip
Yes sir I saw that. But how to you pull the clip back on after you replace the bulb?
Anyhow, does anyone think there's enough room in there to change the bulb? On the driver's side I had to loosen and relocate the fuse box. Now on the passenger side The ABS unit is like 3cm behind the bulb cover!
I got the clips loosened. Like I say above, I have no idea yet how I'm going to get the outboard clip back on... I just can't seem to get the cover to come out of there.
One does do these bulbs from inside, rather than taking the front lens off right?
Thanks very much for your replies.
Old Jan 29, 2010 | 08:47 AM
muddyjag's Avatar
the clip is easyly put back on with a long screw driver , i had no problems replacing the bulbs , the cover can stay in gap there is enough room to replace bulb
Old Jan 30, 2010 | 06:35 PM
zyggo's Avatar
Cool. I didnt think there was room. It's bloody cold around here so I didn't spend too much time on it! Thanks!!!
Old Jan 30, 2010 | 08:30 PM
queenmb's Avatar
Red face
If all else fails, get someone with small hands to reach it. I never have a problem removing mine. It takes about 5 minutes and never had to loosen or relocate anything.
Old Jan 31, 2010 | 10:52 PM
zyggo's Avatar
Oh if I had such help!
Thanks for the advice all.
Old Sep 27, 2011 | 04:32 PM
bulkmail07's Avatar
I did not see the answer to my question here or just did not recognize it. 2004 X-Type. Is there a trick beyond brute force to removing the H1 bulb from its socket? I am afraid of breaking the socket if I attempt to pry the bulb out. Really appreciate any suggestions. Thanks all
John/2004 X-Type (wife's car)
Old Sep 27, 2011 | 09:42 PM
Green Machine's Avatar
Smile
I just replaced bulbs in my front fog light. They were the original bulb and were really stuck in the sockets. I just used a small screw driver and worked the old bulbs back and forth until I was finally able to pull them pull them free. I would imagine this method will work for all of the H1's.
Old Aug 30, 2016 | 06:20 PM
  #28
Harry Peter Rose's Avatar
same problem but cannot get the bulb out!
screw or out pull out? .........could it be fried??
what and from where did you get a replacement?
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 3, 2015 07:32 PM
