A/C compressor
Old Apr 27, 2014 | 06:26 PM
Noxparadise's Avatar
Default A/C compressor
Has anyone changed their AC compressor? How hard of a job is it? Is it worth trying to do or should I pay someone? I've changed quite a few things on my car but I have seen where it's at so it seems like quite the job.
James
Old Apr 27, 2014 | 09:58 PM
ltmax's Avatar
Had to take mine off a few weeks ago to change the oil pan gasket, it was only 4 bolts and it sits right at the bottom of the engine so it's very easily accessible from underneath.
Don't imagine that it's too difficult of a job.
Old Apr 28, 2014 | 09:32 PM
Anything special you had to do? How much does the AC compressor cost? I think I've read you have to take off a belt?
Old Apr 29, 2014 | 07:19 AM
ltmax's Avatar
If you've never done it before I'd take it to an independant garage. Labor should only be a few hours as it's only dropping the engine splash shield, removing the 4 mounting bolts on the compressor, disconnecting one electrical connector, serpentine belt, and two a/c hoses.
For the stuff that needs to be replaced, besides the compressor/clutch assembly itself ($110 e-bay) anytime you open up your a/c system it's best to change out the pressure hose with dryer ($20 e-bay) on the system, draw a vacuum on the entire system to remove any moisture, and refil with the correct amount of refridgerant and oil.
Plus dumping your a/c charge into the atomosphere isn't legal in most places and could get you into trouble.
bdboyle
Sep 16, 2019 05:58 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
