A/C Low Side Valve Location
Old Jul 4, 2009 | 02:57 PM
FearTheLeaper's Avatar
Default A/C Low Side Valve Location
Did a search on the forums but couldn't find the answer. Probably the dumbest question of the year but I'm just wondering where exactly is the A/C's low side valve located? Thanks for any help...
Old Jul 4, 2009 | 03:55 PM
Thermo's Avatar
Veteran: Navy
Looking at the JTIS, it says the low and high side ports are next to each other in the right rear corner of the engine compartment. You can tell the difference between the two in that the high pressure side will run between the condensor (located in front of the radiator) and the dash where the low pressure port is going to be between the dash and the receiver (small metal bulb in the return line, which then leads to the compressor).
Hope this helps.
Old Jul 4, 2009 | 10:15 PM
canman's Avatar
Location is correct, but the direction of flow you'll find is not so clear, however the Low Side connects to the larger tube which is clearly visible.
Old Jul 5, 2009 | 01:42 PM
Thanks guys, found it. Kind of in an awkward spot, I can barely put my hand around the cap to pull it off. Thanks again...
Wolfy
May 28, 2024 08:06 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
