A/C Problem
Old Jun 18, 2015 | 05:50 AM
joseph1945's Avatar
Default A/C Problem
Hi, I am new to the jag forum, I just bought an X Type 2003 2.0 diesel, the problem I have is the A/C button on the dash won't turn off unless I turn off the blower and then the A/C goes off, is there a way around this fault or is it just me not knowing how to turn the A/C off???????
Anyone else had this problem and how do you get around it if you can, Cheers, Joe
Old Jun 18, 2015 | 02:31 PM
dwclapp's Avatar
joseph: Welcome to the JaguarForums. Lots of useful information here from friendly folks who enjoy our X-Types and like to help each other keep them running smoothly.
By chance, is the air blowing at your windscreen? If 'yes', try re-directing the air to blow at your face or feet, then see if you can turn off the A/C.
A "design feature" of our cars is to turn on the A/C whenever the air is directed at the windscreen, because the A/C removes moisture from the air, and dry air quickly evaporates condensate from inside the windscreen.
Old Jun 18, 2015 | 02:47 PM
wa3ra's Avatar
The manual actually tells you to put the system in 'auto', and the computer handle it.
Old Jun 18, 2015 | 03:17 PM
joseph1945's Avatar
Hi guys, thanks for the info, to answer dwclapp, yes the air is blowing at the windscreen and has been more or less since I got the car as we have had a fair bit of rain, I used it to clear the misting on the windscreen and it's still set that way, I will be trying your solution ASAP and I will let you know how I get on, thank you.
to answer wa3ra, I never received a manual or any owners info with the car so I am pretty much flying blind at the moment and any info of any sort is very welcome at the moment, thanks guys.
Old Jun 18, 2015 | 03:22 PM
joseph1945's Avatar
Hi again, many many thanks to dwclapp, fantastic, that's exactly what the problem was brilliant, as I said, I never got any owners manual or info with the car so I did not know of this situation, thank you so very much, Joe
Old Jun 18, 2015 | 03:26 PM
I'm pretty sure the AC light will be illuminated when you are in auto mode, although the compressor may not be engaged all the time.
Old Jun 18, 2015 | 03:48 PM
joseph1945's Avatar
Norri, thank you for the information, I hope you don't mind I have printed it off for future reference, thanks a milliion, Joe
Old Jun 18, 2015 | 03:55 PM
No problem, you can get the whole thing here https://topix.jaguar.jlrext.com/topi...document/index this is the North American link but if you hit the US/English link at the top you can go through the set up and select the UK version.
Rivguy
Dec 4, 2020 07:55 AM
Dicque
Sep 19, 2015 12:53 PM
Saturbo
Sep 8, 2015 07:35 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
