A/C problems
Old Jul 11, 2014 | 01:59 PM
slenser's Avatar
Default A/C problems
I'm having trouble with my 2005 X's a/c. I hooked up the gauges and it reads 23-low and 215-high at 100 degrees. Any idea what the problem could be? It's the coolest when sitting at idle. At least it feels that way.
Edit:
BTW, it doesn't cool down at all when running. I can't run it like this with the heat.
Old Jul 11, 2014 | 03:12 PM
Tony_H's Avatar
The problem is you haven't told us enough!
Is the LP line cold and the HP line hot? Is it blowing air? Are there codes? Filter installed and OK?
If you want a wild guess try the temp blend door/actuator.
Old Jul 11, 2014 | 03:42 PM
slenser's Avatar
The real problem is I don't know what I'm doing! HAHA!
I took it to a local shop and they quickly pointed out that there was .43 lbs of refrigerant in the system. No idea how my gauges read what it did. I'll be taking them back to Harbor Freight.
It has a hole in the condenser hose going to the compressor. $200 for that, refill of refrigerant and about 2 hrs labor brings it just over $500. It's just too hot to drive with this heat. The hole is from a screw that rubbed it's way through the line.
Still no idea how I got the readings I did with nothing in the system, but at least it explains things.
Rivguy
Dec 4, 2020 07:55 AM
Dicque
Sep 19, 2015 12:53 PM
Saturbo
Sep 8, 2015 07:35 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
