Can I do this???
Old Jan 26, 2018 | 12:46 PM
Chris Hebb's Avatar
Default Can I do this???
Can I take the amp from a 2002 or a 2003 xtype and put it in my 2004 xtype. I'm asking because there are 3 xtypes at my local pull a part. There only 20$ for the amp. So I want to see if this is something I can do before I go all the way over to pull the amp and buy it
Old Jan 26, 2018 | 02:26 PM
avern1's Avatar
My first question is your old one gone bad? Or are you looking to add an amp?
The 2002, 2003 and the 2004 up until April 2004 have the same wiring harness. After April 2004 the wiring harness was significantly changed. You would need to look at the wiring diagrams for the 2002 and if you are built after April 2004 compare that wiring diagram.
With that out of the way anything is possible given sufficient time and money.
Old Jan 26, 2018 | 02:31 PM
Chris Hebb's Avatar
Only my 4 tweeters are working. Checked the fuses for the amp and wires on the back of the stereo. Looked for loose wires. Can't find anything wrong so I'm thinking the amp itself is bad. Only because it's highly unlikely for 6 speakers to blow at 1 time. So I figured I got pull an amp off one of them and try it out.
Old Jan 26, 2018 | 02:41 PM
Chris Hebb's Avatar
Mine says it was manufactured in February of 2004 on the sticker inside the door but I'll still take a look at the diagram
Old Jan 26, 2018 | 03:20 PM
x_type_lpg's Avatar
yes they are plug compatible, the mounting brackets may change.
Old Jan 26, 2018 | 03:59 PM
avern1's Avatar
With the feb 04 build date anything from 2002 or 2003 will work.
rashaw
May 8, 2012 07:37 PM
Disco stu55
May 12, 2010 02:57 AM
viscoussquirrel
General Tech Help
Jan 9, 2010 12:55 PM
Eric
Jan 6, 2010 06:26 PM
