Bluetooth phone
Old Jan 26, 2018 | 04:02 AM
jaguarxjordan's Avatar
Default Bluetooth phone
Hi guys,
My X type gives "No phone" when press phone button. That means there no phone module . So my question is could it be easy install the module as plug and play as DIY or needs professional installation. If someone have a good write up would be much appreciated. Thanks
2005 X Type 2.1 v6
Old Jan 26, 2018 | 03:25 PM
x_type_lpg's Avatar
yes easy add, you need the mic to go in the roof near the light module, the loom from the boot to the rear seat, a bluetooth phone module its a silver metal box that goes in the boot cage for the dvd/cd player, and a btum unit to plug into the loom to act as txrx for the bluetooth signal.
Old Jan 26, 2018 | 04:16 PM
Dell Gailey's Avatar
Just do a search. Many (again MANY) posts of requirements and process. Even a small one on the stickie on the opening home page.
EXAMPLE =
X type Phone/Bluetooth Installation
Old Jan 27, 2018 | 09:49 AM
DC2003's Avatar
Or, you can get a Bluetooth to FM adapter. That will allow you to make and receive calls and stream audio like Pandora from your phone. It’s Much cheaper and easier solution.
DC
Old Jan 27, 2018 | 10:23 AM
DC
LPg, Dell and DC would like to thank each one of you. I found a Microphone in the dome light Stuff and i think that means wires are already equipped in this car. But there is no Bluetooth or Voice activation module as well. Let me start with factory stuff then will think about cheaper aftermarket. Thanks again guys
Jaguarjc
28
Jul 26, 2018 05:58 PM
bfair
Aug 22, 2013 09:35 PM
WinterJag
Aug 4, 2013 06:03 AM
dsetter
29
Mar 25, 2013 04:30 PM
rothe
Audio/Visual Electronics
Dec 5, 2010 03:38 PM
