Can I temporarily use water insted of antifreeze in my 2.5?
Old Aug 28, 2011 | 08:20 AM
Riche$$'s Avatar
Default Can I temporarily use water insted of antifreeze in my 2.5?
Can I temporarily use water insted of antifreeze in my 2.5? I have to replace my water pump (leaking around pulley shaft) but I can't do it right away.
Old Aug 28, 2011 | 10:20 AM
Max's Avatar
Max
You can, but one of the primary reasons for an ethylene glycol and water mixture (50/50) is to raise the boiling point of the liquid in the engine from 212 degrees F for plain water to 265 degrees F for a 50/50 anti-freeze solution.
Personally, I wouldn't take the chance.
Old Aug 28, 2011 | 11:39 AM
Me neither, unless it was a get home measure.
Your water pump is only going to get worse, and there is a risk of it failing all together, not only leaving you stranded but also risking engine damage.
PS, it helps if you state the model of your car, X Type I would think?
Paora
Feb 4, 2021 12:36 AM
mikiep
Dec 20, 2019 07:37 PM
Spazzzzzzzzzy
Oct 4, 2015 05:37 PM
Lubrication
Oct 1, 2015 03:56 AM
millertic
Sep 30, 2015 08:11 PM
