Car doesn't start
Old Aug 23, 2015 | 05:30 PM
Twal1stjag's Avatar
Default Car doesn't start
Hello everyone, this my in the forum, this twal1stjag from Va.
I have a 02 Jag X-Type that's been sitting over 9 months. I've recharged battery and gases her
up, still doesn't start . I could use a little help, thx
Old Aug 23, 2015 | 06:05 PM
Welcome to the forum Twal1stjag,
I've moved your question from General Tech Help to X-type forum. Members here with the same model will be able to help.
Old Aug 23, 2015 | 06:56 PM
Thermo's Avatar
Veteran: Navy
Twal, lets start with the obvious and then we can go further from there. When you roll the key to the START position, does the message center say something to the effect of "Security Fail" and/or the center console has a solid red light? If so, your problem lies with the security system of the car. Write back and we can take things from there.
Next, as you roll the key to the RUN position (not the START), can you hear the fuel pump run for a few seconds and then turn off? If you can't, then it is possible that you have a bad fuel pump from sitting. You can try spraying a little bit of starting fluid into the intake (there is a nice hole to squirt some in right on top of the intake). IF the car fires now and runs for a second or two, then this would confirm a fuel pump issue.
Not to ask a silly question, but does the radio turn on? If not, then you may have a wiring issue where the power to the cabin of the car is affected which will have an effect on the car's ability to start. Along the same lines, then you roll the key to the RUN position, does the "Check Engine" light come on? If no, then your ECU is not getting power and therefore the car will not start.
Lets see what you have at this point and then we can take it from there.
Old Aug 23, 2015 | 07:45 PM
Dr dome's Avatar
also check for mice tracks. They love to chew wire bundles. (most of the harness are made from soy...(why I don't know)
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
1964Daimler
Sep 2, 2015 11:41 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
