Cell Phone Charger Won't Work
Old Aug 15, 2007 | 05:22 PM
Default RE: Cell Phone Charger Won't Work
Hey Angie........welcome to the forum .....hope you enjoy and I'm sure you'll find it useful.
Sorry I cant help with your problem but no doubt someone will be along soon who can
Jim
Old Aug 15, 2007 | 08:29 PM
bigdreams05's Avatar
Hey angie, sounds like a problem with contacts of your lighter. You said the lighter works, as a lighter. How about other car chargers, do they work on your lighter? If not, then buy one of those splitters! I doubt that would work, but you never know!
Old Aug 16, 2007 | 12:26 AM
SpartanX's Avatar
fuse - never ignore the obvious because that's exactly what was wrong with mine. A simple fuse that took me 30 seconds to replace.
Old Aug 16, 2007 | 09:17 AM
tradertcb's Avatar
I did have a radar detector that came with a sleeve that fit around the plug and I did need it for my Porsche. I had exactly the same scenario, lighter worked, but radar detector didn't. Sounds like the sleeve is what you need. Best I could figure was that the sleeve gave additional size to the plug, and that in itself kept the center contact where is was supposed to be. Does your plug "wobble" a bit when in the lighter? If so, the sleeve will work. Might be time for some electrical tape as a quick fix. I would go to the cell phone manufacturer site or call the vendor where you got it.
Old Jun 12, 2021 | 06:51 AM
zaidahmad22a's Avatar
When you center your smartphone onto a wireless charging pad, the only thing you’ll notice is the change of your battery icon from its standard mode to a battery with a bolt in the middle, signalling your phone is actively being charged. Best android chargers online. Wireless charging is also referred to as Qi charging or Qi technology. The Qi standard was introduced in 2008, so the technology is relatively new. Qi uses both resonant and inductive charging, of which the latter requires devices to be close to each other in order to work.
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
tberg
Sep 7, 2015 07:32 AM
Charlene n John
Sep 6, 2015 11:03 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
