Center console changes?
Old Aug 24, 2013 | 12:24 AM
Shaguar4's Avatar
Default Center console changes?
This might sound like a stupid question but does anyone know if it is possible to get a newer x type center console with touch screen, ect.. to fit correctly in a 03 x type?
Old Aug 24, 2013 | 06:25 AM
Thermo's Avatar
Veteran: Navy
Shaguar4, first off, welcome to the forums. You will find lots of good information here. Just stop by the New Member Section and give us a little introduction. We are quirky in that we like to get to know one another.
As for your question, yes, the center console will bolt right in. No major structural changes were made during the run of the X-Type (01-09). So, you can swap around parts and all should be good. Now, there are slight changes when you are flipping between the standard radio and the Navi radio (ie, the touch screen). That is not a simple "plug and play" mod. You have to add a lot of stuff to the car to make the Navi work. You would be better off getting an aftermarket head unit for say $700 than to try and retro fit the factory unit in. If you want me to go into more detail about this, let me know. If you do some looking, this question has been asked a few times before.
Old Aug 25, 2013 | 11:12 AM
Shaguar4's Avatar
Well I just finished my introduction on the New Member Section! Now as far as the center console goes I have thought about an aftermarket set up as that is what I had in my last car, however the shape of the center console seems very specific. My concern would be how it would fit? Would there be an unusual gap between the aftermarket setup and the original pieces or is there going to be a big spacer block that’s going to just sitting there to hold it in (both of which I would not be a big fan of)?
Old Aug 25, 2013 | 01:15 PM
Aonsaithya's Avatar
The big spacer block is the only solution I've seen here. There are plenty of old threads on installing an aftermarket headunit in the X-Type, do read them. There's important stuff such as how some deeper headunits don't fit in the top 2 slots because of some climate control thingy behind the dashboard.
Old Aug 25, 2013 | 03:36 PM
Thermo's Avatar
Veteran: Navy
Shaguar, unfortunately, if you are looking aftermarket, you are going to be force to use the spacer block. Other members have used them and what they did was to color match the plastic with the color of the radio or with the rest of the plastic for the center console. So, are you willing to have the looks of the plastic trim or pay the bigger dollar to have all the factory components installed.
Old Aug 25, 2013 | 09:38 PM
Shaguar4's Avatar
Well I guess those are my only options then. I’ll have to look around to see which way I go on that. If I put an aftermarket setup in does the climate control that is stock go out the window or would that hook up somewhere?
Old Aug 26, 2013 | 12:44 AM
Aonsaithya's Avatar
I did see one car with the climate control panel hidden in the glove box, but that makes little sense to me really.
Attached Thumbnails Center console changes?-rycka-albums-jaguar-x-type-picture1965-30.jpg   Center console changes?-38083160017_large.jpg
Old Aug 28, 2013 | 04:51 PM
Shaguar4's Avatar
I like the way that looks a lot. I'm definitely gonna go with an aftermarket head unit! Thanks guys for the help.
Swagguar
Aug 11, 2019 04:50 PM
adam699
Oct 13, 2015 05:53 PM
goingjag
Sep 30, 2015 09:27 PM
42Ajd
Sep 26, 2015 07:04 PM
