changed n/s front door. not locking or unlocking with fob
Old Jul 19, 2012 | 05:21 AM
zee's Avatar
zee
Default changed n/s front door. not locking or unlocking with fob
HI, im a newbie!!! really struggling here i have a jaguar x type 2004 2.0d. the car has been damaged on front n/s door. i have replaced the door and the door is not locking or unlocking with keyfob. rest of door works. if i sit inside and lock or unlock the passenger door the whole central locks and unlock. but if i sit in the driver side door lock and unlock all does work apart from the from passenger door. do you know what i mean? will it needs programming?
Old Jul 20, 2012 | 01:23 PM
disguay's Avatar
This does not need programming and I have actually had this exact same thing happen to me before. What is happening is that the motor in your actuator is being overpowered by increased resistance within the cable that is going from the actuator to the inside door handle. To fix this, simply remove the door panel, and then lube the inside of the cable which should have red ends on it. The important thing to do now, is make sure that if your whole car is locked or unlocked that you manually toggle the passenger door to match the other doors otherwise you will burn out the motor inside of the actuator and you will need to buy a new one rather than just lubing up your old one. If you have any questions, just let me know
Old Jul 28, 2012 | 06:15 AM
zee's Avatar
zee
hi thanks for your help. iv tried that its working but with key fob everything unlock and lock apart from the passenger door. i have swapped my damaged door complete from scrap yard with all mecanism and motor. assuming needs programming as it is a difrent door from a dif jag
Old Aug 1, 2012 | 01:59 AM
disguay's Avatar
I have never had a problem with using a junkyard actuator before, but if you are using a whole different door, I may be wrong as I see there is another member who is also having similar issues with replacing a whole door assembly. Try pulling the ground off of your battery to allow the car to "relearn" that it has a new door, or try reprogramming your keyfob to see if that works.
Old Aug 1, 2012 | 02:53 AM
+1
You may have to do a 'hard reset'. After removing the negative battery cable, short it to the positive terminal for about 30 seconds. This discharges all capacitors clears memory.
D.K
Dec 10, 2023 02:05 AM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
