Changed o2 sensor & now x won't start !
Old Dec 18, 2017 | 10:54 AM
myexcursion's Avatar
Default Changed o2 sensor & now x won't start !
had a p1646 error and changed out the sensor. A real PIA to get to, but after cutting the wires was able to fit a socket over it - o2 socket kept spinning off
Put in the new one, turned on the car drove it forward about 100 feet and reverse back into the driveway. Got into it this morning and everything looks normal except it will not start. I can hear the fuel pump and all the other clicks, just Nothing else. I even replaced the battery on the key Fob - and nothing. At one point I did hear turn over quickly for a half second. Since then nothing.
also try jumping the battery - same result
any fuses or any other things I can check?
Old Dec 18, 2017 | 12:35 PM
NBCat's Avatar
Do you mean the starter turns the engine, but the engine doesn't start, or do you mean there is no response when the key is turned to START?
Old Dec 18, 2017 | 12:46 PM
i can hear everything except for the start. Clcks , fuel pump Etc ... But just dead silence when turning key all the way to start.
thx
Old Dec 18, 2017 | 01:23 PM
NBCat's Avatar
Check relays and loom connections for something that has been disturbed during the oxygen sensor replacement.
You can also try to move the shift lever whilst turning the key to start.
Old Dec 18, 2017 | 02:37 PM
yep tried it in both P and N - same no crank. All connections seem fine as well in loom
What fuses or relays do you suggest checking ?
Also what is best way to test the starter ?
Thanks !
Old Dec 18, 2017 | 05:03 PM
Default Updaye
Thanks !
Update -
took a deep breath and looked at it again after getting home from work this afternoon. - Felt around the starter and found the starter selnoid nut was very loose and the yellow cable was not making firm contact. Tightened it down and cranked right up !
thanks again all all for their input - issue resolved.
82WingNut
Apr 4, 2017 08:49 AM
JagsteRJX
Sep 26, 2016 06:58 AM
usajay38
Mar 15, 2014 06:36 PM
Samantha
Mar 26, 2013 06:33 PM
Rockyf
Aug 6, 2010 11:28 AM
