Help, changed belt, replaced compressor now s type won't start
Old Jan 21, 2014 | 07:24 PM
usajay38's Avatar
Default Help, changed belt, replaced compressor now s type won't start
Guys, I removed air intake tube, unhooked the one sensor, remove belt, started vehicle for two seconds to be sure it was bad compressor. I replaced compressor and belt now vehicle will not start. It just turn over and over. I fully charged battery, checked schrader valve for fuel. What did I miss or do?
Old Jan 21, 2014 | 07:39 PM
QuartzSTypeR's Avatar
Make sure all the sensors (MAF) are fully plugged in and you didn't snag any when you pulled the compressor out.
Old Jan 23, 2014 | 08:03 AM
usajay38's Avatar
If I place a multi meter on MAF connection, what reading should I get? 12 volts.
Old Jan 25, 2014 | 07:25 PM
usajay38's Avatar
Old Jan 26, 2014 | 06:05 AM
usajay38's Avatar
I removed everything again and can't find any loose wires.
Any help.
Old Jan 26, 2014 | 07:28 AM
clubairth1's Avatar
Community Influencer
Did you try to start it today?
With the early cars like yours and what you did (2 seconds of running then shutoff). You might have bore wash. So no compression while cranking because the oil on the cylinder walls has been washed off with fuel.
The first few seconds of engine operation from a cold start is very rich. So when you shut it off the fuel is left in the combustion chambers.
I would try shooting some starting fluid in the air intake while it's cranking. You need two people for that.
Can you hook up a battery charger while you crank the car? You really want full voltage for everything.
Old Jan 26, 2014 | 10:01 AM
JagV8's Avatar
If it's bore wash, and indeed with the 4.0 it may be, have a read of previous threads for fixes. Essentially no money but some pain. Could be a lot worse!
Old Jan 27, 2014 | 11:39 AM
usajay38's Avatar
It appears to be a bad fuel pump.
Old Jan 27, 2014 | 01:02 PM
tbird6's Avatar
OK but your first post said you had fuel at the schrader valve?
You don't now? Have you checked the interia switch?
It's very odd for a running car to have no fuel after a simple repair so changing the pump might not fix your problem?
Old Jan 28, 2014 | 07:10 PM
usajay38's Avatar
The fuel in the valve just sat there when I pushed it. It never stayed out. I checked the fuel pump connection and there is power but pump is not turning on.
Old Jan 28, 2014 | 07:11 PM
usajay38's Avatar
The switch is fully pressed down
Old Jan 28, 2014 | 08:35 PM
abonano's Avatar
The OP mentioned the car sat around for a month in between the repair (via PM's) and that resulted in the no start condition I believe
Old Jan 29, 2014 | 01:03 PM
tbird6's Avatar
Did you get it started?
Old Mar 15, 2014 | 06:36 PM
usajay38's Avatar
New fuel pump, she's riding smooth again.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
1964Daimler
Sep 2, 2015 11:41 PM
Drew2006
Aug 28, 2015 04:22 PM
