Changing air & oil filters
Annoying that the air filter box (w/screws) is so hard to open. And why does changing the oil filter also require so much extra work?
-- press release writer Press Release Writer Ron Goodden
Received 3,825 Likes
Gddn, I do not see it as being all that difficult. Personally, I would rather see the screws than having a box that has clips on it. But that is me. As for the oil filter, it is more the angle at which you attack the filter. Then there is also being smart and not tightening the snot out of the oil filter when installing it. The rubber gasket on the oil filter expands as soon as the oil is applied. So, install the filter and as soon as you feel it starting to get snug, you stop. Should be able to spin the filter off just after installing it with 2 fingers. So, when you get ready to change the oil when it is due, you can grip the filter with your hand, give a flip of the wrist and the filter will spin off.
Lcgi (10-19-2012)
