My x currently has 225-50-16’s and would like to use a set of tires that I already have that was used last year during winter that was on my other car which is a 2011 Lancer. The tires I want to use are 205-60-16. Which are all 4 studded. Anyone think the jag may have a problem with the tire size difference even tho all 4 will be of the same size ?
I think you'll have problems with the (+3.2%) increase in diameter and circumstance.
In the U.S. You can call a Discount Tire center and on their computer they can input any tire size for any vehicle and tell you if you'll have clearance (rubbing on bumps, turning, etc.) problems.
Yeah, I understand that. I still believe you'll have issues with rubbing but, as suggested call a Discount Tire place and have them input the car and tire into their computer program. I did this a bit ago when changing all 4 (17") tires and ended up just going standard. I was trying to get a bit taller and wider fit.
