Check engine codes
Old Mar 20, 2007 | 09:42 PM
altownsend's Avatar
Default Check engine codes
2002 X-Type 2.5 Automatic, 63,000 miles
I have recently been getting a light in the dash. It is a red circle with an exclamation point (!) in the middle. When that happens, the idle is high and non-controlling. I turned the engine off and waited for about a minute, and started the engine and all was fine, until the next time. Today, it happened again. Only, this time, the check engine light came on. I took the car to get the code read. These are what they found:
P0121
Throttle Position Sensor, Pedal Position Sensor A CKT Range/Perf
P1111
Manufacturer Control Fuel Air Metering
Anyone know what my solution is?? Thanks in advance
Old Mar 21, 2007 | 10:54 PM
racerx82's Avatar
Default RE: Check engine codes
Sounds like your TP sensor needs too be replace
Old Mar 22, 2007 | 02:56 AM
altownsend's Avatar
Thanks racer,
I will replace it and see if it solves my problem. Al
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Dec 6, 2021 07:13 AM
jehart49
Sep 12, 2015 05:36 PM
dcvickers
Sep 2, 2015 06:14 PM
TC Johnson
Sep 2, 2015 09:30 AM
