check lite
Old Apr 15, 2012 | 04:26 PM
vwguy777's Avatar
Default check lite
p0105 code and intermitant miss. thoughts?
Old Apr 17, 2012 | 11:24 PM
PreJag's Avatar
P0105=Map Sensor circuit malfunction. There's either an open between the sensor and ECU, or the Map is shot. Good Luck.
Old Apr 18, 2012 | 04:02 AM
jmarshall's Avatar
Post
P0105: This code is for bad Manifold Absolute Pressure (MAP) sensor. MAP sensor provides instantaneous manifold pressure information to the engine's Engine Control Module to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering for optimum combustion.
Mac Allan
Oct 27, 2015 04:49 AM
ccfulton
Sep 20, 2015 05:15 PM
amaezing
Sep 18, 2015 03:25 PM
eurotire
Sep 18, 2015 07:27 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
