"Christine" Door
Old Jul 8, 2009 | 02:46 PM
teflondon's Avatar
Cool "Christine" Door
Sometimes my passenger door opens from the outside fine and sometimes it doesn't. I have to open it through the driver side. I looked at the locking mechanism and it seems to be fine. Has anyone experienced this problem ?
Old Jul 8, 2009 | 04:41 PM
Platinum Sport's Avatar
Funny that you brought this up.
My 06 has the same "Christine" door LOL, and here I thought I was the only one
Old Jul 8, 2009 | 04:51 PM
Thermo's Avatar
Veteran: Navy
Don, to check the operation of the door handle, you will need to remove the inside of the door. Now, with the door unlocked, observe the reach rod running between the exterior door handle and the latch mechanism. Does this rod start to move as soon as you start to move the door handle? If no, then you are probably looking at a bad exterior door handle. if the reach rod moves as soon as you move the exterior door handle, then you are more than likely looking at a bad latch mechanism.
Of note, if the door operates every time from the exterior when you manually unlock the doors, then you are looking at a bad lock/unlock motor for the door lock mechanism.
Hope this helps.
Old Jul 8, 2009 | 07:25 PM
Guys, this is a well documented issue usually on the older 02's and 03's.....and the fix is pretty much as thermo says ( nice one )
Check out the X type FAQ quick link for a step by step on how to remove the door panel
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
al_roethlisberger
Sep 21, 2015 08:07 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
