Clunking sound in front end
Old Jun 28, 2010 | 10:38 AM
monz87's Avatar
Originally Posted by L.Rob
Hi. I have a 2004 x-type 2.5. When going over rough roads, there is a clunking sound in the front end that you can feel through the steering wheel and gas pedal. On smooth roads it is perfectly quiet. The steering is tight, and the handling seems normal. I put it on a vehicle and everything seems tight. The only thing that I found is a light clicking sound when pushing down on the right front end when it is on the ground. Any ideas? It is driving me crazy, and the dam thing sounds like it's going to fall apart. Thanks for your help!!
It could be worn anti roll bar bushes and links, it is quite common
Old Jun 30, 2010 | 01:52 PM
kimguidry's Avatar
Default Struts
I changed both front struts, made a world of difference.
Old Jun 30, 2010 | 07:51 PM
jaguar04's Avatar
hi all
i havving similar problem with my 04 jaguar xtype 2.0 LE
Clunking sound in front end when hit hump or rough road , i had replace new front break pad changed break fluid
KimGuidry==>changed both front struts, do I have to get original part ?
Old Jun 30, 2010 | 07:52 PM
jaguar04's Avatar
sorry for asking too much question
thanks
Old Jul 1, 2010 | 07:17 AM
TonyX's Avatar
When changing struts, besure to check the condition of the top mount bearing. The ball bearings in mine were worn so they were replaced at the same time. It's no sweat to change them while strut are replaced.
I also replaced the anti-roll bar bushings. It was real pain to get that done - front subframe drop, use alternate bolt, very limited working space.., You can read more on my thread titled 'Ride improvement'.
mbergen
Oct 23, 2019 10:26 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
XKR-NC
Sep 4, 2015 08:23 AM
