Code: P0353
Old Jan 17, 2015 | 04:01 AM
ugotmale's Avatar
Default Code: P0353
Guru's, I've read two Shop Manuals and for whatever reason the info left me wondering if I was missing something.
One Manual says: P0351/P0353/P0355 is a failure of coils 1A, 2A, or 3A and then lists P0352/P0354/P0356 as failure of coils 1B, 2B, or 3B.
In an attempt to put 2 and 2 together I suspect the last digit is indicative of cylinder. But what is the "A" and "B" mean? And is it possible to get one of these codes and have to replace all 3 coils?
Second Manual says: quite frankly, P0353 is a failure of #3 coil. That seemed entirely too straightforward.
Can someone confirm 0353 is #3 cylinder Ignition Coil Failure?
Can someone chime in on what the order is as well? 1,3,5 is firewall and 2,4,6 is radiator?
GO HAWKS!
Old Jan 17, 2015 | 04:41 AM
Extract from the Workshop manual on cylinder numbering:
Code: P0353-cylinder-numbering.jpg
The relevant section is "..... correct cylinder numbering is, when viewed from the rear of the engine, the right-hand cylinder bank is numbered 5,3,1 and the left-hand cylinder bank is numbered 6,4,2."
Jaguar have a confusing way of referring to cylinders on all models and at times documentation switches between using LH or RH and A or B bank.
According to the Jaguar DTC listing, P0353 is Ignition module primary circuit
malfunction on cylinder 3.
Old Jan 17, 2015 | 08:58 AM
Thermo's Avatar
Veteran: Navy
ugotmale, please note that in the pic that GGG posted, it uses a slightly different point of reference than what we normally use here. His has you standing by the driver's wheel (for you, or by the battery) and then looking at the engine that way. Normally I would tell you to stand by the passenger wheel (for you, or near the washer bottle fill) and then look at the engine that way.
When standing at the passenger tire (for you), the odd numbered cylinders are on your left with 1 nearest you and 5 furthest away that are also hidden under the intake by the firewall and the even numbered cylinders have 2 closest to you and 6 furtherest away with these hidden under the air box and close to the radiator.
Use the reference point that makes the most sense to you.
As for the code, your P0353 is referring to cylinder number 3. Keep it simple. I think the A and B numbering is referring more to a cylinder on a side of an engine away from a reference point. For example, cylinder 3B would be on the B side of the engine (aka, Bank 2, or the radiator side of the engine) and would be the 3rd cylinder from the reference point (assuming that the reference point is the front of the engine which would be near your passenger wheel). It is all in how the engineer that come up with the referencing decided to number things. Lots of ways to number the engine.
Old Jan 17, 2015 | 01:22 PM
ugotmale's Avatar
Thanks Thermo and GGG. I was really hoping 1,3,5 were the easy ones to get to. Good to know it is in fact the coil (for starters). We'll see what happens after I replace it......
Old Jan 17, 2015 | 08:06 PM
Thermo's Avatar
Veteran: Navy
ugotmale, too bad it wasn't a month ago. I was out in your neck of the woods (stayed in Bremerton). Could have come over and turned a few wrenches with you.
Old Jan 22, 2015 | 03:15 AM
ugotmale's Avatar
Yea, that would've been convenient! Probably would've learned a few things too. Unfortunately my car has very bad timing. It'll be nice when it feels pampered enough to let me go more than a few weeks without tweaking out. It's like a domino effect, once one thing goes something else follows!
Old Jan 28, 2015 | 02:39 AM
ugotmale's Avatar
Default Update
Just to update anyone eying this thread. I haven't had the P0353 code since I originally posted this. The weather warmed up around here quite a bit too and could be a factor. So for now it's a wait and see. Now that I've posted this, either it will come back or something else will go wrong.
Roland M
XJ40 ( XJ81 )
Sep 12, 2015 02:25 PM
Jhartz
Sep 2, 2015 11:05 AM
PinnacleWax
Detailing / Car care
Aug 26, 2015 11:44 AM
PinnacleWax
Jul 24, 2015 11:35 AM
lazboytt
Jun 3, 2008 05:02 AM
