Code p0417 2003 Jaguar x-type
Old Feb 17, 2014 | 03:36 PM
therealest8guy's Avatar
Default Code p0417 2003 Jaguar x-type
I have checked for vacuum leaks, IM O-rings replaced, breather is new ribbed, vacuum brake line checked, MAF sprayed w/ maf cleaner. CEL comes on after 5 minutes(later in mornings. Car will run fine if I reset with obd II , until I turn ignition off, I will then have to repeat process. I think it goes into limp mode while CEL on, hesitates at 2500 rpm. I bought the car new, has 99,700 miles, no issues till now. HELP!!! Code is p0174, not p0417, dyslexia flare up, can not edit title.
Last edited by therealest8guy; Feb 17, 2014 at 04:51 PM. Reason: wrong code should be p0174
Old Feb 17, 2014 | 04:02 PM
Five Speed's Avatar
P0417 Jaguar Secondary Air Injection System Switching Valve B Circuit Shorted may help....
Old Feb 18, 2014 | 08:57 AM
JagV8's Avatar
P0174 is quite common - fastest is to read existing threads, I guess. Be sure to read all known causes listed in JTIS.
h4wk
Nov 27, 2015 05:10 PM
neruda
Sep 3, 2015 07:45 PM
big d
Sep 3, 2015 07:37 PM
Dion Petty
Aug 30, 2015 01:00 PM
Terrance Williams
Aug 26, 2015 11:50 AM
