Coil spring
Old Jun 7, 2013 | 06:51 PM
Fezz's Avatar
Default Coil spring
I am looking to purchase a pair of coil springs, but I've noticed some are suitable for a "sport suspension" and some are not. Is there any way to find out which coil is suitable for my car? Mine is the 2002 3.0 Sport but I'm not entirely sure if it came with the sport suspension or not.
Thanks.
Old Jun 8, 2013 | 06:48 AM
Thermo's Avatar
Veteran: Navy
Fezz, if you got the Sport version, then it came with the sport suspension. It would be a rarity if it didn't. Worst case, you should be able to get under the car and look on the coil springs. There should be a sticker on one of the springs that you can then type into a Jaguar parts listing (try "Jaguar Parts" - Jaguar parts and accessories catalog) and that will give you a lot of the info that you are in search of.
The difference between the Sport and non-sport suspensions was a slightly shorter shock in the Sport version and the springs were 1.4" shorter. The rest was trim decoration and interior options.
Old Jun 8, 2013 | 07:35 PM
Fezz's Avatar
Always there to save the day, thanks Thermo!
Old Jul 23, 2013 | 07:44 PM
chiefshb's Avatar
So if I were to buy sport shocks/struts and sport springs (or lowering springs...whichever would be cheaper) I would have a "sport" suspension, in theory?
Old Jul 23, 2013 | 08:50 PM
Thermo's Avatar
Veteran: Navy
chiefshb, to the best of my knowledge, yes. There may be a slightly different sway bar. But, I don't recall there being something special about that. The rest of the "sport" upgrades were all visual (no chrome around the windows, no chrome on the corners of the car, special interior colors/wood, etc) But, you would have a sport as it relates to performance.
Old Jul 24, 2013 | 05:20 PM
Quartz X-Type's Avatar
Just curious...why are you looking to replace the springs?
Old Jul 25, 2013 | 08:58 PM
Fezz's Avatar
The spring is damaged due to a massive pothole. The bottom of the spring is rubbing on the assembly. Therefore, when I make a sharp turn it makes a grinding sound due to the stress put on it. Been looking and I still cant find anything. Jaguarparts.com seems to have been shut down. Phone line and all isnt responding.
Old Jul 25, 2013 | 09:19 PM
Thermo's Avatar
Veteran: Navy
Fezz, then give these guys a call. I have used them and been very happy with them. I am sure that they will be able to help you out.
http://www.gaudinjaguar.com/parts-center
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
sunchip
Oct 5, 2015 02:05 PM
Bcrary3
Sep 27, 2015 12:21 PM
