cold starting
Old Dec 21, 2011 | 11:36 AM
matthewa's Avatar
Default cold starting
My 2.2SE estate (59 plate) has had a fault for nearly a year. With the dealer scratching head.
When starting from cold, the engine sounds a bit rough. Then engage drive or reverse and the car starts jerking, in an attempt to drive off, though revs still about 800.
As soon as engine temp off the red, the engines purrs fine and the auto gearbox behaves without jerking.
Looked at EGR, replaced fuel filter (improved a bit).
The dealers problem is he only has about 10mins from cold to find a remedy, then has to leave for 3-4 hours to cool down again.
anyone know of this problem or the solution?
Old Feb 19, 2012 | 02:40 PM
plpleung's Avatar
Hi Matthewa,
Just brought a 58 x-type 2.2SE, had exactly the same problem, have you found a fix yet?
Old Apr 3, 2012 | 06:25 AM
matthewa's Avatar
Hi plpleung
After the dealer having the car for 2 weeks, replacing the entire fuel line and fuel pump, it still carried on.
Finally it was resolved. Turns out the fuel pump was faulty, but the software had adjusted the injectors. So changing the fuel pump may only a small difference. It was rectified by obtaining new software codes from Jaguar.
The car is now more powerful than before.
Old Apr 4, 2012 | 04:48 AM
plpleung's Avatar
Dear Matthewa
Many thx for the reply. since it is warming weather now it is much better, but still doing it on a COLD morning, anyway will bring it in to Jagaur and ask them to do the same as yours.
How much does changing the the Fuel pump cost at the dealer? I think someone told me new software is around 100 pounds.
Many Thanks again.
Patrick.
Old Apr 10, 2012 | 03:01 AM
matthewa's Avatar
I was lucky, still under warranty - so dont know how much it was.
aholbro1
Dec 29, 2024 06:46 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Bones
Sep 8, 2015 08:34 PM
tberg
Sep 7, 2015 07:32 AM
