Common problems
Old Jan 20, 2012 | 11:53 AM
cel2620xl's Avatar
Default Common problems
Hey fellow X-type. What the most common problem with the X-types? please feel free to comment .
Old Jan 20, 2012 | 03:30 PM
disguay's Avatar
Transfer case and differential being low on fluid.
Drive shaft bearing going out and making noise in the cold.
Defroster vents not fitting correct and rattling
Steering wheel cover becoming deformed
Rear calipers freezing up
Headlights breaking
Wheel sensors becoming rusted and causing faults
Blend door failing
speakers blowing
Old Jan 20, 2012 | 03:34 PM
bgr's Avatar
bgr
well I just picked one up cheap a 2002. the drivers door lock does not lock and once put in gear makes a sound like it is locking 3 or 4 times but the drivers door remains unlocked and the manual knob on the inside of the door handle stays in the locked position.
the water pump is leaking.
the hood shocks are worn out.
the car makes a beeping sound for the first 60 seconds while driving.
let me know if anyone knows the exact quick fix for the beeping and door locks. thanks...
Old Jan 20, 2012 | 09:16 PM
Thermo's Avatar
Veteran: Navy
bgr, the water pump is a really easy thing to change out on this car. After doing it, you will wonder why you waited so long.
As for the door lock issue, it is the latch mechanism in the door that is binding up and not pulling the cable to move the door latch. So, you need to get in and clean up the door latch really good and then apply some lube to the latch to ensure everything moves easily.
Old Jan 21, 2012 | 12:20 AM
05xtypeee's Avatar
are these common problems any specific year dependent?
Old Jan 21, 2012 | 07:06 AM
Thermo's Avatar
Veteran: Navy
05xtypeee, the transfer case issues are more common in the 02-03 years, but the 04+ years are not immune to it. Everything else is pretty much standard throughout all the years.
Old Jan 22, 2012 | 03:38 AM
cel2620xl's Avatar
Is this for the all wheel drive X-type?
Old Jan 22, 2012 | 07:53 AM
Thermo's Avatar
Veteran: Navy
Cel, yes, the AWD X-Types have the transfer case. If you have the diesel variant, it is only 2wd and therefore does not have a transfer case. But, any X-Type that you find in the USA will be AWD as jaguar did not import any diesel or 2wd X-Types to the US.
Old Jan 22, 2012 | 12:02 PM
bgr's Avatar
bgr
As for the door lock issue, it is the latch mechanism in the door that is binding up and not pulling the cable to move the door latch. Sound clean up the door latch really good and then apply some lube to the latch to ensure everything moves easily.
thanks alot. I am doing the water pump this week and will dig into the door panel later as well.
Old Jan 23, 2012 | 02:13 PM
disguay's Avatar
Bgr, I also had troubles with my door locks and ended up having to buy a new door actuator and install it. I bought it off of ebay for about $50 from a junkyard. That's what you will have to do if the lube doesn't work, but the lube is necessary in both cases
Old Jan 23, 2012 | 02:15 PM
disguay's Avatar
Also, the beeping probably has something to do with the door lock problem. I will drive mine with the door ajar and see if it beeps at me.
Old Jan 23, 2012 | 04:59 PM
iownme's Avatar
I bought mine cheap also...i had/have some issues but don't regret it one bit!...the more you fix...the better it rides, unlike new cars which just get worse over time.
Old Jan 24, 2012 | 05:55 PM
Thermo's Avatar
Veteran: Navy
iownme, you are in Rochester, right? If so, I am heading back up your way in October. I will more than likely be staying at the Extended Stay America there in Greece. Just giving you a heads up.
Old Jan 24, 2012 | 06:14 PM
sanche's Avatar
Don't forget about the vacuum leaks also fellows...
Old Jan 24, 2012 | 09:18 PM
cujet's Avatar
My 2003 had the liquid filled "aft" lower control arms leak all the fluid out. Come to find out, it happens after 10 years down here in Florida.
Old Jan 25, 2012 | 07:18 AM
iownme's Avatar
Thermo... i lived in Rochester when i first moved to the U.S. I now live in PA during the week and go home to Oneonta NY for weekends. I'm about 3 hrs from Rochester now.
When the weather gets warmer i'll likely take a weekend trip to your neck of the woods.
T'would be nice to meet up with you.
Have a great time in NY and dress WARM...lol...Rochester gets very cold!
Old Jan 25, 2012 | 03:30 PM
Thermo's Avatar
Veteran: Navy
iownme, I grew up in Toledo Ohio. I know how cold it can get. I am not too worried. I actually like the colder weather. Bring on the snow!!!!!!! If you make it down to the DC area, let me know. I will see what is going on and we should be able to meet up.
bamforp
Aug 14, 2024 05:36 PM
jaggermang
Sep 8, 2015 07:07 PM
MrMellor
Sep 7, 2015 10:22 AM
XKR-NC
Sep 4, 2015 08:23 AM
Jjscruggs1
Sep 3, 2015 07:46 PM
