Console light is what? 2002 X Type
Old Mar 11, 2015 | 08:12 PM
akejama's Avatar
Default Console light is what? 2002 X Type
OK, I've been through the manual 3 times and I must be blind because there is a light mounted on what looks something like a micr. or air duct shield on top of the center console behind the shifter. That light comes on and blinks. After I drive it a while it goes off. I cannot find what the function is and what the slotted piece it's attached to does. It's probably there but I can't find it. Is this the low battery light? I'm lost. thanks.
Old Mar 11, 2015 | 08:45 PM
Norseman02's Avatar
I have a 2004 and a red light at about the location you describe I believe indicates the Super Charger is on. Mine doesn't blink; my neck hurts sometimes though.
Old Mar 11, 2015 | 08:48 PM
sawduster's Avatar
The slotted piece you refer to is a coin holder. On models with DSC there is a button there that allows you to turn off the DSC. The blinking red light above it indicates the security system is activated. On mine, it goes out when I unlock the doors.
Old Mar 11, 2015 | 09:40 PM
sov211's Avatar
That is the coin holder and the red light is simply the alarm/security indicator. When you lock the car that light will begin to flash; when you unlock it is should stop flashing. If that red light flashes while you are in the car then there is a defect somewhere in the system - most likely something very minor - for example a sticking gate in the ignition switch - when you remove the key a small gate falls - you should hear it click when you remove the key. I would begin by thoroughly lubricating the ignition switch and all of the door lock mechanisms (the security system takes its signal from those lock mechanisms).
Old Mar 11, 2015 | 09:42 PM
sov211's Avatar
Sounds like fun but you are talking about a totally different model of Jaguar. There are no supercharged X-Types, and the light in question is simply the security system flasher.
Old Mar 12, 2015 | 09:53 AM
akejama's Avatar
Default Thanks Folks
Hey thanks for the info. I knew it would be something blatantly obvious but I'm willing to feel stupid to resolve an issue before I get a load of costly grief. We've had 3 or 4 weeks of sub-zero weather and I think maybe some moisture frozen in one of the locks may have been the issue. I cleaned, oiled, and the light is gone. I appreciate you taking time to respond. While true this car doesn't have a turbo assist I will now refer to the security light as my Turbo Light. It sounds so much more classier. **grin** I love ya all and once again thanks for making my Jaguar experience a little easier.
Tom
Old Mar 12, 2015 | 05:55 PM
Norseman02's Avatar
Ok I get it-you are humor handicapped. Regarding your response of "no supercharged X-types" I have to disagree. Otherwise I have had something else that looks a great deal like a supercharger re-belted and upgraded with different pulleys.
Thanks anyway for the useful info.
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
Rusty1952
Sep 1, 2015 05:45 AM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
