Coolant Flush
Old Oct 20, 2012 | 12:51 PM
Fezz's Avatar
Default Coolant Flush
Was just wondering where the drain release is for the coolant. I've pointed out where the coolant goes, but I want to be sure I'm not removing something else when I'm looking for the drain point to flush out the old anti-freeze/coolant.
Thanks a lot.
Old Oct 20, 2012 | 01:34 PM
Thanks a lot.
This could help identify the drain plug.......
Old Oct 20, 2012 | 04:25 PM
Thermo's Avatar
Veteran: Navy
Fezz, look under the front of the car on the passenger side of the car. You will see a small hole with the slotted fitting shown in the above picture. Just a warning though, if you leave the plastic plate in, the fluid will sometimes run all over the place and can make it challenging to collect all the fluid.
Old Oct 21, 2012 | 12:05 PM
Fezz's Avatar
Am I going to have to remove the plastic cover underneath held by a million screws first?
Old Oct 21, 2012 | 12:21 PM
Thermo's Avatar
Veteran: Navy
Fezz, you do not need to remove it just to drain out some coolant. BUt, be ready with 2 or 3 pans to start collecting coolant. May be advisable to put a jack under the driver's side of the car and lift that side up say 3 inches or so to make the passenger side of the car lower than the driver's side. That way, if any coolant hits the tray, it will run to a specific corner and will make collecting the coolant easier.
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
vwbusbits
Oct 13, 2015 03:43 AM
