coolant leak
Old Jan 2, 2008 | 09:45 AM
Default RE: coolant leak
Hey there zero n welcome to the forum mate.
Re the fan - see below
Sounds like itsthe tinyfan which carries on running in humid conditions to circulate the air so you don't get blasted by warm air when you use your climate control.It circulates air across the humidity sensor.
It keeps running for a while after you switch off, and starts again
when you open a door. It does this so that there is less delay in
getting the climate control to the right setting when you switch on
(or restart )
Jim
Old Jan 2, 2008 | 09:58 AM
No Zero, sumthins definitely up.
You need to get it checked before you do anythin else I'd say.
Anyone else have any ideas that could help?
Jim
Old Jan 2, 2008 | 12:05 PM
310jag's Avatar
You can't replace components of the water pump, only the entire assembly. They're only ~$75. I had to replace mine about 3k miles ago. It's the easiest thing I've done to the car. Remove the battery (and lower half of plastic battery box), remove the three or four nuts that hold the pulley to the water pump, then remove the 12 or so bolts that hold the water pump to the block. You'll loose about a gallon of antifreeze, maybe a bit less. Refit the new pump with the included new gasket, refill with the appropriate coolant, and life is good.
Once you get the battery out of the car you'll see how easy it is. Good luck!
Old Jan 2, 2008 | 07:18 PM
jag_genius's Avatar
they usually leak from the front seal area.. or sometimes the gasket which you can get separately.. 80-120 from the dealer..
Old Jan 2, 2008 | 09:07 PM
310jag's Avatar
The dealer wanted $150ish for the pump itself. I got mine from a local NAPA store for $75. Welsh Ent. and other Jag parts dealers have them for the same price. I'm sure you can source on locally. Every place I called around here had a couple in stock.
The shaft connecting the pulley to the impeller had a fair amount of play in it, so mine was definitely more than a gasket. At water pump really should fail at 28k miles, but I wouldn't be *surprised* if it needed to be replaced. It couldn't hurt to replace it.
Old Jan 7, 2008 | 07:31 AM
Dennis's Avatar
ud
There is a simple procedure..I can't remember exactly at the moment..But unless someone else mentions how today, I will post the procedure tonght..
BTW..did you buy the high dollar anti-freeze from JAG?....When I did my flush, I think I paid around $75.00 for a gallon of their concentate....Also make sure you always mix it 50/50with Distilled H2O.
arskemp
Sep 21, 2015 02:19 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
