Coolant leak tracing
Hi
UK Heatwave, time to get under the Jag, now I have a list of things to do, first coolant.
Following the hoses, noticed many are very squeezable, much to my surprise.
How do you tell if a hose is heading to end of life?
And then spotted lovely crystals growing from what seems to the a square block behind the thermostat housing, apparently their is a seal for this? can't get either a clear view in the car or any diagrams. Is this seal a usual problem? Can it be reseated or needs replacing, not seen any discussion on this, also seems to be a huge difference in price for replacement.
While in there should I consider changing the thermostat etc at the same time?
Many more questions to come, as always TIA
After a cold soak, preferably overnight, use a cooling system pressure tester to pressurise the system to 1 bar. The pressure tester gauge should not begin to drop after fifteen minutes. If the gauge begins to drop, use a torch to inspect the engine compartment for signs of coolant leaks.
If you don't know the service history of the vehicle, it may be best to replace all the cooling system hoses at the same time given the age of the vehicle.
SNG Barratt have the hoses and other parts needed to refurbish the X400 cooling system.
https://www.sngbarratt.com/English/#...r=1&layoutId=G
about the coolant leak... - that is the thread with the information you are looking for:
https://www.jaguarforums.com/forum/x...ne-end-286532/
I had quite a leak there, and I fixed it.
Kuddlesworth
Oct 23, 2024 12:43 PM
