Coolant reservoir nipple broke: can I fix with barbed brass fitting?
Old Jun 9, 2014 | 05:25 PM
harryc's Avatar
Default Coolant reservoir nipple broke: can I fix with barbed brass fitting?
I noticed that my temp was fluctuating slightly. Popped the hood and found that the nipple on the top of the coolant res cracked. I can easily fix by removing it totally and threading in a barbed brass fitting of equal size.
Would anyone here see a problem doing that?
Old Jun 9, 2014 | 06:25 PM
Jac's Avatar
Jac
That's exactly what I did. I heated the brass fitting with a heat gun or you can use a propane torch. Just make sure you don't heat too much. Just enough that it slowly melts into the hole. Left it cool and connected the hose. I know that everyone says you have to buy a new tank but I thought I would try that first. Never had a leak since. Been almost a year.
Old Jun 9, 2014 | 06:49 PM
harryc's Avatar
Why does everyone say to buy a new tank? I know the tank is only like 50 bucks, but wouldn't this fix be just as good if not better?
Old Jun 10, 2014 | 07:38 AM
Paulc732's Avatar
I just tapped the hole with 1/4 NPT and screwed in a brass fitting with some gasket sealant around it. Have not seen any leaks and its been over a year.
Old Jun 10, 2014 | 12:55 PM
jetjack's Avatar
I took a piece of aluminum tubing and inserted it in the two broken halfs and applied a little JB Weld its been in there a couple thousand miles now, no problems.
I just bought a new tank and all new hoses, belts, and intake seals and going to give a good service next nice day
KarimPA
Sep 12, 2015 08:15 AM
OkieTim
Sep 8, 2015 04:48 PM
prettydaim
Sep 4, 2015 09:13 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
