Cooling fan question.
Old May 10, 2013 | 12:18 PM
innzane's Avatar
Default Cooling fan question.
Search found me all answers, but one question.
Does the cooling fan run after key is removed? assuming engine is at the temp that would require it to run.
Car seems to be running a lil hot, not by the gauge but my senses, and I recall many cars run the fan after shutdown. So worth asking b4 I do anything.
Old May 10, 2013 | 12:36 PM
bracester's Avatar
Nope, mine shuts off when I turn the ignition off...it can be modified however with a 2nd radiator fan circuitry setup though so the fans keep running until it reaches the set temp...it would but a serious drain on the battery over time though...
Old May 10, 2013 | 01:56 PM
innzane's Avatar
Cool, thx for the info. I am gonna do the AC check and see if both fans are working then go from there. Wife might have used cheap gas, could be the sounds I hear.
Old May 11, 2013 | 07:51 PM
Green Machine's Avatar
Thumbs up
If the engine is actually running hot (dis-regarding gauge reading) then the fans will continue running until the temperature is down to normal.
I know this because I blew a hose and temp went in to the red on the gauge before I got home since most of the coolant was gone. The fans run for almost 15 minutes after turning the ignition off.
Old May 13, 2013 | 09:11 AM
innzane's Avatar
I was doing some checking and it seems the fan cuts off with ignition under normal operating temps, but if you do get the engine hot they will continue to run after shutting off the ignition.
I found the lil nub the sticks out the passenger side of the coolant resivor had a crack in it, the one with the small 3/8" hose that runs to opposite side of the motor. Got a temp fix on it but a new tank would make me feel better.
Old May 21, 2013 | 08:50 AM
innzane's Avatar
Well the parts car at the local yard did not have the collant resivoir so again I had to MacGuyver it.
The cracked nipple broke off the other day, probably from pressure. Emptied my tank and sent lights flashing, but no harm done since we were on the lookout for it and ready.
What I ended up doing was taking a file to the broken nub filing it flat, I then enlarged the hole and tapped the plastic with 1/4-18 threads and used a common 3/8" brass airline hose connector threaded into the hole as my new nipple. I would call this a permanent fix, all went well.
Nice to have that worry off my mind!
Old May 21, 2013 | 06:22 PM
Kota62's Avatar
innzane:
did you dry fit the brass or use some type of RTV
Gary
Sleestak
Aug 17, 2022 11:22 AM
mikiep
Dec 20, 2019 07:37 PM
CXJ
Aug 29, 2017 08:41 AM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
