Could it be the Intake Manifold Gasket or the dreaded Head Gasket ? ...
Old Feb 11, 2018 | 11:29 AM
Harry Peter Rose's Avatar
Default Could it be the Intake Manifold Gasket or the dreaded Head Gasket ? ...
Posting this for 2ndtime ….post has disappeared …Any thoughts most welcomed!
2002 2.5 awd/auto./petrol// hopefully located coolantleak....left hand side of engine...
a pool of coolent sitting below where the two metalpipes join..{just beside intake manifold}...not sure if coming the pipejoint?..
where else could be the leak be from?...... Couldit be the Intake Manifold Gasket or the dreaded Head Gasket ? ...
Old Feb 11, 2018 | 07:39 PM
Thermo's Avatar
Veteran: Navy
harry, well, considering that the intake manifold gaskets do not have coolant running through them, you can scratch that one off of your list. Now, before you jump on the "bad head gasket bandwagon", lets see if we can narrow things down a little bit.
If you are suspecting a pipe joint, then I would say to get yourself a rag or some paper towels and wrap the joint in question, making sure to keep anything burnable away from the exhaust. From there, you can take the car for a 5 minute drive and see if you have any coolant on the rag when you are done.
When you say left hand side of the engine, are you referring to as you look into the engine bay or if you are in the driver's seat? I don't have my X-Type any more, so, I cannot look at the pipe in question and it is not coming into my mind. If you are referring to the left side relating to the driver's seat, then I would be going after the overflow bottle first as that is the more common problem (either broken nipple on the back side of the bottle or a crack on the underside that only leaks when the engine is up at temp). Granted, this also makes me wonder if you don't have a coolant hose that runs from the overflow bottle to the far side of the engine that may have a crack in it that could be causing what you are seeing.
Old Feb 12, 2018 | 08:04 AM
avern1's Avatar
I posted a new response in the other post you ave for this problem.
If one of the moderators happens along maybe they can combine your duplicate posts.
ltshaneclarke
Oct 23, 2018 06:24 PM
Rogelio Serrano
Nov 25, 2016 07:10 PM
steuey67
May 24, 2012 03:42 PM
xjrwithproblems
Oct 20, 2011 11:58 PM
BugDoc
Aug 16, 2009 12:24 PM
