cruise not available?
Old Nov 16, 2014 | 09:02 PM
deviousgentleman's Avatar
Default cruise not available?
CEL is on, and shows banks are lean. Car runs rough if I try to accelerate at a normal speed when this is displayed. Any ideas of what could be causing this. I recently gutted the cats and put spacers on the two sensors plugged into the cats... Also when it is around the 40 degrees and lower range it displays something about low temperature outside. I can not get that to stop displaying for the life of me. If I click the button on the side of the turn signal it disappears for a small amount of time and reappears... Drives me crazy. How do I disable it? Thanks!
Old Nov 17, 2014 | 07:20 AM
Thermo's Avatar
Veteran: Navy
Devious, lets start with the easier problem first. The low temp indication will come on every time you start the car and the temp is less than 40F or the temperature drops to less than 40F after the car is started. To get rid of this message, if you look under the headlight switch, you will see 3 buttons there. The middle button says "RESET". Momentarily press that button and the "LOw Temp" indication will go away.
As for your cruise not available indication, odds are you are suffering from a vacuum leak. I would first start wtih checking the PCV hose and making sure that the underside of that hose is not split. THis is especially true if you have the smooth hose (vice a ribbed hose). After that, you may have bad IMT valve o-rings and/or a cracked check valve on the brake booster hose (runs between the top of the intake to the brake booster).
Start with this and then we can take things further.
Old Nov 18, 2014 | 08:48 AM
Noxparadise's Avatar
I agree with thermo, I already replaced my PVC hose twice, it was once split down the middle and then the last one the attachment that goes over the intake manifold had a crack on the corner underneath. I would of never known had I not moved it, once I touched it I could tell, that would be the first place I would look.. its very simple just take off the heat shield off the top of the engine and it'll be to the right on top. It goes from your air filter box to your manifold.
MrWhite
19
Jun 14, 2022 07:49 PM
sg997tt
Oct 9, 2015 10:57 PM
MrWhite
Oct 1, 2015 01:43 AM
goingjag
Sep 30, 2015 09:27 PM
