Cylinder 5 misfire I made it worse!
Old Jul 15, 2019 | 08:43 AM
ken736cc's Avatar
Default Cylinder 5 misfire I made it worse!
Hi,
2002 X Type sport 2.5. I have had a check engine light and codes P0305 and P1316. Yesterday I replaced cylinder 5 spark plug and injector. The coil is a known good unit. Upon start up the engine revs about 1800 rpm, the throttle is unresponsive and the dash message center is flashing "engine system failure" "gearbox failure " and "DSC failure" . I double checked my work . There are no fuel leaks. The connector to the throttle actuator on the throttle body is brittle and may be making a poor or no connection. I will check this today. Am I on the right track? Any help greatly appreciated.
Ken
Old Jul 15, 2019 | 09:01 AM
Alfadude's Avatar
Was the idle speed good before you did the work? If so, then I would guess you are on the right track with what you are going to check. The work you did would not cause teh idle to go to 1800 RPMs I would think. You must have disturbed something else while working in there.
Old Jul 15, 2019 | 09:44 AM
ken736cc's Avatar
Hi,
The car ran great even though the check engine light was on.
Old Jul 16, 2019 | 09:22 AM
ken736cc's Avatar
Fixed ! Thanks to help on this forum and this post CLICK HERE .
The throttle actuator connection was so disintegrated that it fit upside down. When I checked and saw that I had the green wire on top i knew that was the problem. I switched the wires and the Jag now runs as normal.
Thanks everyone.
Ken
Old Jul 16, 2019 | 09:45 AM
Alfadude's Avatar
Glad you finally got it sorted after all that aggravation.
Old Jul 16, 2019 | 02:57 PM
Dell Gailey's Avatar
Wow, that's a new one, lol!! Congrats on sorting it out.
dc4prez
Jun 15, 2020 06:28 AM
Lanny
Dec 18, 2012 07:44 AM
Dirkman
Aug 30, 2012 06:53 PM
crittie7777
Sep 9, 2009 04:07 PM
