dear god help me..........
Old Feb 22, 2008 | 10:31 PM
jvegas's Avatar
Default dear god help me..........
I have searched and searched and can’t find an answer to this question: how do you adjust the headlights from side to side? My passenger head light is aimed too far left. I found the screw to adjust them up and down, I also found another screw which I thought would move them side to side but, nothing happens when I turn the screw! Is there something special I must do? Has anyone ever done this? Thanks for any help!
Old Feb 22, 2008 | 10:41 PM
H20boy's Avatar
Default RE: dear god help me..........
uh oh, that doesn't sound good...a screw that doesn't do anything? That adjustment mechanism may be broke. Pics please...
Old Feb 22, 2008 | 10:44 PM
jvegas's Avatar
what do you want pics of?
Old Feb 22, 2008 | 10:58 PM
one's Avatar
one
There are NO adjustment screws for side to side. Only up and down. The projectors are preset from the factory and cannot be changed.
It's the dumbest *** thing I have ever seen.
Old Feb 22, 2008 | 11:05 PM
jvegas's Avatar
then what does that other screw do? and how did my paassenger light end up pointing so far left?!?
Old Feb 22, 2008 | 11:08 PM
one's Avatar
one
you unseated the projector lock.
Old Feb 22, 2008 | 11:18 PM
jvegas's Avatar
how do i reseat it?
Old Feb 23, 2008 | 07:03 AM
FactoryJaguarTech's Avatar
Make sure the bulb is inserted correctly and the spring clip is fully seated around both edges.
Jvegas I havens forgotten about you. I am out of town. Be back Monday and will look for you.
Old Feb 23, 2008 | 10:19 AM
jvegas's Avatar
well i installed those hid's and the clip is hard to fit around the base of the bulb correctly. is there some trick?
Old Feb 23, 2008 | 10:57 AM
aquill1's Avatar
Make sure that you seated it correctly. If you noticed when you pulled the bulb out it has a round edge and than that flat spot. The lights should fit in there really easily. Did you get the mydepot hid kit like most of us? The install should have been in and out in less than 15 minutes per side......If you have any questions or need help give me a ring I'll help you out if I can.
Old Feb 23, 2008 | 11:34 AM
H20boy's Avatar
Sure, give up your name here, but via PM you keep your anonimity.... just razzin ya TONY. Now I know how to address you on the phone when you get down here.
keep at it jvegas, you'll get it seated correctly and clipped. be patient...
Old Feb 23, 2008 | 06:29 PM
aquill1's Avatar
I was only leaving there for a minute...never fear it's gone now! He just called but I couldn't help him...I didn't have any problems it was pretty straightforward...his lights may be a little bit different than mine I don't know...
Old Feb 23, 2008 | 07:38 PM
x type lamps are pretty much the same regardless. If bulb not clipped in right, that is the aiming problem.
Just a footnote:
Before ever adjusting your lamps using hex screws, use whiteout or something to mark the starting point so you can put it back where it was. Most times lamps are not misadjusted until someone starts screwing with them.
Old Feb 24, 2008 | 03:58 PM
aquill1's Avatar
So fjt the only adjustments are for the aim are the wheels on the outside of the light right? There isn't adjustment on the inside of the lamp, for instance after you remove the back cover? I'm wondering if the lights shipped were h1's but I don't understand the install was straightforward, something has to be different! LOL!
Old Feb 24, 2008 | 05:02 PM
No adjustments on the inside no.
Old Feb 24, 2008 | 06:27 PM
jvegas's Avatar
ok. there are two screws. one towards the outside of the car and one towards the middle of the car. what does each screw do?
Old Feb 24, 2008 | 06:56 PM
I believe the inner one is vertical aim and outer is horizontal but without putting my paws on it, may be other way around.
Also, we were taught that federal law mandates adjustments for vertical aim only. No horizontal aiming allowed. That may be for hid only though.
Old Feb 24, 2008 | 08:31 PM
jag_genius's Avatar
FJT arent Hid aftermarket illegal ? here they are but no one has inforced it yet..
Old Feb 24, 2008 | 08:37 PM
Yes. Because they can't self level.
Old Feb 24, 2008 | 08:57 PM
aquill1's Avatar
You get the lights installed right jv? I wish I could have been of help for you...
