Door open light won't go off
Old Jul 20, 2018 | 06:43 AM
Drakester's Avatar
Default Door open light won't go off
X type 2003 ,my cars door open light won't go off ,and when I lock it with the fob horns sounds twice and interior light stays on
Old Jul 20, 2018 | 08:30 AM
avern1's Avatar
One of the door micro-switches is not operating. The switch tell the SCLM that the door is closed.
I would recommend spraying down the latching mechanism with penetrating oil (wd-40) in an effort to free it up.
Worst case you will have to remove the door card and replace the switch.
Old Jul 20, 2018 | 03:04 PM
Dell Gailey's Avatar
Locking with fob and 2 honks is the PATS saying a door is ajar. As Avern suggested check the door switches, and the hood and the trunk. DO NOT spray lubricant in the hood latches as there is a TSB saying it causes the switch to die.
Is there a door, hood, trunk notice on your message center if you sit in the car? Or try sitting and locking while inside?
Old Jul 20, 2018 | 03:07 PM
Another thought, as you drive off from initial start and the auto locking all doors engages, do a physical look and check to see if they are all indeed locked (drive, locks, someone outside tries each door). If a door opens, that's probably the one with the problem.
Old Jul 20, 2018 | 03:10 PM
My message center says things like this = rear passenger door open or boot open. If it's telling you which door is open......there you go. Fix it.
JimC64
Sep 22, 2025 02:52 PM
xk8newbie
Feb 3, 2017 10:20 PM
macboots
Oct 13, 2016 08:26 AM
S Daddy
Oct 9, 2016 10:26 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
