Door Panels refitting issues
Old Dec 28, 2025 | 01:17 PM
PCjags's Avatar
Default Door Panels refitting issues
Hi All,
My Gold kitty, 2004 2.5L Petrol V6 Manual has been neglected for a while. I had removed the door cars for reasons forgotten and went to put them back together with new clips.
2 issues
First I broke a number of the clip holders on the door card itself - any suggestions on how to fix?
Second, I used all new White clips purchased, all the old one broke.. now these will not stay in the fixing in the door, they are identical size to the old ones... Suggestions welcome
TIA
Old Dec 28, 2025 | 02:38 PM
cat_as_trophy's Avatar
Any chance you can epoxy the clip holders back onto the door cards?
Best wishes,
Old Dec 28, 2025 | 02:40 PM
Jagboi64's Avatar
The pins are different lengths, some of the originals are pink. I can't remember which ones go where, I just recall that they are not all the same.
Old Dec 28, 2025 | 05:18 PM
iownme's Avatar
i just removed and replaced mine and all the pins are pink, same size
Old Dec 28, 2025 | 05:57 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...29/#post132944
This guy always has great informative and easy to follow videos =
Old Dec 28, 2025 | 08:27 PM
PCjags's Avatar
Dell
that look like an interesting idea will try that cheaper than new cards
TIA
Old Dec 29, 2025 | 03:47 AM
iownme's Avatar
interesting product
Old Dec 29, 2025 | 07:10 AM
Peter_of_Australia's Avatar
DO I understand correctly that you issue is that the old door panel clips are broken?
Why don't you buy new ones?
They should be available to buy on Aliexpress.
Old Dec 29, 2025 | 09:13 AM
PCjags's Avatar
Hi Peter,
Its the clip holders on the door card itself that are now broken, so nowhere for the clips to clip into to then push into the door.
by the way in reply to the comment about pink, I measured the new white clips (pins) against the old white and pink pins and they are the same size, looking to source the retaining parts that are in the door now to see its them that have now worn out.
Anyone replaced those? where from?
TIA
Old Dec 30, 2025 | 12:40 AM
It's a while since I had my door panel off...
Can you send a picture of the parts you are looking for?
Old Dec 30, 2025 | 03:54 AM
iownme's Avatar
you may remember, the door card pins, push into small round black plastic "grommets" which are pressed into the door panel itself, occasionally one of those grommets will either break, or come out of the door affixed to its pin when pulling off the door card.
Old Dec 30, 2025 | 06:27 AM
PCjags's Avatar
found the part, on the trusty X-type 2001 - 2010 (x400) Classic / Door Casing-front | Jaguar Land Rover Classic Parts site.
part 9 only available at ridiculous prices for plastic
Also parts for the green, pink and brown pins... who knows which one ones go where
Old Dec 30, 2025 | 07:23 AM
The sketch is not all too clear, but I think you may be able to find what you are looking for on Aliexpress & dead-cheap:
I looked on Aliexpress for "Jaguar X-Type door panel clips" and "Jaguar X-Type door inserts for panel",
And I found this:
https://www.aliexpress.com/item/1005...origin_prod%3A
Now, it is possible that you cannot open those links (it may only be possible to open those exact like in Australia), but you should find the same, if you look with those keywords on Aliexpress.
Here is the screenshot of that link:
Old Dec 30, 2025 | 09:24 PM
iownme's Avatar
nice find.
the pin is not the same but the base appears to be.
link did not work so copy/paste this text into aliexpress of your country
these are not on ebay or amazon
20X For Jaguar S-Type Vanden Plas X-Type Snap Sack Inserts Grommet Fender
Interior Door Card Trim Panel Clip Fastener Stud Plug
Old Dec 31, 2025 | 06:32 AM
PCjags's Avatar
Peter, that's a great find, my searching there did not turn these up but I can see them from your link.
I'll have a poke about later and compare the sizes
Many thanks and Happy New Year
Old Jan 1, 2026 | 06:10 AM
I hope you find the right link.
Happy new 11111101010, to you too (that is 2026 as binary number... )
Old Jan 2, 2026 | 10:53 AM
PCjags's Avatar
Same to you Peter, Happy ..--- ----- ..--- -.... (in morse)
I am also finding Ford and Land Rover similar parts by using the search word snapsac
( with a schoolboy snigger)
Also learnt a valuable lesson and a New Years resolution, don't try extracting the clips or the snapsac's they rest in while the out temperature is just above freezing (centrigrade)
Old Jan 3, 2026 | 12:23 PM
Jagboi64's Avatar
I took the door panel off a 2007 car, this is the front right side. I labelled the colours. I don't know what the pin is at the middle top
The pink pins are 1-1/4" long overall, the green pins are 7/8" overall.
When I remove the door cards, I have a pair of duckbill pliers that I get under the pins and the pliers spread. That lifts the pins out, instead of putting any force on the door card itself.
Old Jan 3, 2026 | 11:26 PM
95naSTA's Avatar
I tried to repair my 24 year old door card plastic clip holders a few times with plastic adhesive and also plastic welding. It would hold for a couple months max then let go. I decided to put riv-nuts into the door sheet metal and use shallow head fasteners under the wood trim. One issue is the metal clips for the wood trim were meant to be in the inside of the panel and it's difficult to remove the trim in one piece without access to the inside. The clips actually work if they're put on the cabin side of the panel but they still grab the trim hard. I just added some sacrificial foam tape so the trim would stay in the clips but would still pull out. It's been working great for over a year.
Old Jan 4, 2026 | 04:23 AM
iownme's Avatar
some pins may have been replaced before by previous owner.
im pretty sure they are all the same length from factory
